Brake controller adapter 2026 Bighorn?
ncbandit
Wilmington
I can't locate an adapter to plug an aftermarket brake controller into the port on this 2026 Bighorn. It appears Dodge changed the port type. The only ones I can find are for 2024 and earlier. Any suggestions are greatly appreciated.
2003F350
6.7 CTD
Out of curiousity, why not get the integrated controller components and get them activated? From what I've read it's not too difficult to install everything, the wiring is all there, and if you have the proper programmer you can activate it yourself (or it's about an hour at a dealer). Then you get actual proportional control to your trailer brakes, instead of relying on 'simulated' proportional control, or worse a pendulum.
