Aftermarket car alarms
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I've thought about putting one on mine ever since it got ransacked in my own drive and some stuff was stolen. Can I get a system that is just an alarm and no remote start since I already have factory remote start?
Yes, Viper sells just the alarm portion of the system and no remote start included.
myoung84
Tulsa, OK
2012 Power Wagon
Yes it is and awesome! Haha.
I just reprogrammed it. Now it takes 2 presses to activate. I guess I just overlooked that setting when I was programming it.
I would get one with remote start. It will work much further away than the stock remote start and there is no sense in carrying 2 remotes...
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Sweet. My back up is 1 way soft key stick remote that's hidden around the undercarriage. Would be a good assurance to have that 2 press option.
Check the manual too when i get home.
Is it a Viper 5701? All the remote starts I have had in the past you can set it up like for 2 presses but this one I am apparently not able to do.
Edit: Never mind, I'm an idiot, it's in the manual. Going to reprogram now!
zuiquan1
JB Charleston, SC
why do you hate the factory remote start. Mine works well
Mostly because its not 2 way and the range sucks. Also the signal is weak or something because sometimes it doesn't start...then its not 2 way so I don't know if it started and walk out into the cold only to find it didn't....
With my viper it has a screen, I knew if and when my truck started, if someone was messing with it, and even the temperature inside the cab. Plus he range was amazing, I could start it in the back of my hanger which fits 6 C-130's inside of it(it was big) also in the backk of wal-mart, etc....
bigbadram1500
Springfield, IL
My husband has a remote start on his truck with a cold start on it. I had never heard of that till I met him. It would start when the temperature outside hit a certain degree, whatever he had programmed it to. There was a couple times it started in the middle of the night. That was freaky till I got used to it LOL
iceman
Banned
avital is a good two way paging system
