Aftermarket rearview mirror backup camera
awp1965
I'm replacing my factory auto dimming rear view mirror 2012 ST with a BOYO Vision backup rearview mirror. Would the factory mirror wiring be pre-wired with a backup signal wire? Could i just use the factory wiring for the +12v, ground and backup signal?
A
awp1965
The rearview mirror requires +12v, ground and a reverse signal lead. I've got no problem with the actual camera, its the mirror.
baum
savage, mn
2015 Laramie
You may be able to find a power and ground at the mirror but no reverse. for that you will have o go to the light itself. its canbus inside the cab.
noraa73
