Air Conditioning compressor Intermittent
Matteo
Calgary, AB
working on figuring out why my AC wont run cold and i found when i turn the AC on, it runs for about 30 seconds, then shuts off, then starts back on and repeats this process. is that normal?
what are some other problems people have run int with the A/C on these trucks? I just recharged it according to those recharge kits and still blows warm.
crazzywolfie
under the truck
is the system holding the pressure? usually they stopped working for a reason. if it leaked all the refrigerant once it will most likely do it again unless you fix the leak.
also are you sure the heater control valve under the hood is there and working? it stops hot coolant from entering the heater core when you got the a/c on
