Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
its a work in progress but here you go im building an intake off the stock one. i just got a 4 inch rubber coupler and a 90 DEGREE pvc elbow now i need to angle it down toward the grille area and it should be good.
Hmmm... With all the cold air intakes floating around... It might be a good idea to use a live data tool to find out if all your hard work is going to net you any kind of change.
Because technically the stock tube is routed from the passenger fender and should be pulling cold air from there.
Not to knock your idea but to see about getting some sort of change for the amount of modifing that needing to be done...
