Air not bowing out of dash?
Armyman14
4.7 V8
Hey there everyone in my 2002 dodge ram 1500 4.7 I have air coming out by the windshield an down by the feet but no matter how high I turn it up or what setting I set it on air will not come out towards my face which would be nice sometimes!! Me and my dad when we bought it figured it would just be a vacuum hose but later we took it to the dealer and they said it was the air box but then I asked the guys at auto zone and they have never heard of an air box. They said it could be the blend door actuator. But there some weird stuff going on with my AC I will list the symptoms below! Thanks everyone! I would really appreciate anyone and everyone's input!!
Problems
1. No air out of the front of dash
2. Sideview mirror defroster light blinks constantly and can't press a button to turn it off
3. Sometimes when I start the car the passenger side in the dash makes like a really weird kinda like a real small faint engine noise(it's not a good engine) haha what could this be?? Or is this multiple things??
TexasRammer
College Station, TX
the "air box" the dealer is talking about is your hvac box(has youre heater core, evaporator, blend doors, mode door and recirc door). Youre problem is your mode doors, the little tab that is used to move the doors is likely broken meaning you need new doors. it could possibly be the actuator but most of the time its the doors.
as to the defroster light thats another issue, not sure whats wrong with that. do you mirror defrosters work?
Armyman14
Armyman14
4.7 V8
Nope they don't. The light keeps flashing and I don't know if their on or off but I can't tell either way. Okay so I need to replace the whole HVAC box
TexasRammer
College Station, TX
Could be just the switch but I really dont know on those.
You dont have to replace the whole box, just the mode doors. The dealer might replace the whole box because its easier on their part and more expensive for you. I would test the actuator first just to be sure. turn the key on but dont start and turn the radio and blower motor off. listen carefully and mess with the mode selector knob and you should be able to hear the actuator moving, it only moves for like a second so listen carefully. you might need to get down close to the floor vents to hear it. if you hear them then your doors are the problem
Armyman14
Armyman14
4.7 V8
Okay, and for this I will need to remove the whole dash correct? I'm not looking forward to that.
TexasRammer
College Station, TX
yup, remove the whole dash and evacuate the ac system. Its a pain but not as bad as it sounds. I did a write up on it if you need any help
Armyman14
Armyman14
4.7 V8
So I just did that test and I so hear the noise when I change from hot to cold
TexasRammer
College Station, TX
move the knob for the mode that changes it from like floor, to front vents and all. thats the one that you want to test
NITROUSCHRIS
consumer of excess fossil fuels
Wisconsin
blown 6.1
Not to thread jack, but i have a Heater Treater repair door kit i bought for my 06. Ended up trading in the truck before i fixed it. Has the 2 most common of the three doors. The are metal with metal ends. has instructions. Yours on the cheap! been on the shelf for 2 years.
Armyman14
Armyman14
4.7 V8
Is that what I would need to fix it?
TexasRammer
College Station, TX
If he has the mode doors. A lot of people that do this fix use these "heater treater" doors because theyre metal and wont break like the plastic ones
NITROUSCHRIS
Wisconsin
blown 6.1
Yes, the problem is when the little servo motors do their self centering routine to find "home" they slightly go past the limit on each side. So they constantly twist at the ends of the doors eventualy breaking them. The metal doors fix this. Its an involved process but the instructions are prety straight forward and if you got time and patience.....WAYYYY cheaper than the dealer. I think the web site is heatertrater.com if you wanna look. I got the kit with 2 of the 3 doors in the heater box. I opted not to get the one that they say really never breaks. The kit i have with control All the floor to defrost setting and all in between. i could still control temp in mine.
Armyman14
Armyman14
4.7 V8
Yeah the temp is fine to but I think I might as well replace that too while I'm in there since they have a problem too. How much would yours cost me?
Armyman14
Armyman14
4.7 V8
I might take you up on that if I can be sure that I need them to fix the problem
