Air Ride Offroad2
wrench78
Air Force Law Enforcement
SE PA
2022 2500 Laramie
6.4L
I did a search but could not find an answer anywhere on here. My question is:
Is there a way to lock air ride offroad 2 mode so that it will stay in that mode past 20-25mph?
Ramsteen23
MA
I don't think so unless there is a way to change/remove the speed limiter setting using Alfa OBD. I've never used it but there are numerous members on this site that can probably confirm if its possible.
chopperman1
2018 Rebel
5.7L HEMI
You can adjust your ride height parameters with AlfaOBD. Essentially making your "normal" height taller. The Rebels ride at OffRoad 1 as their normal ride height. Another option is using Revel's adjustable links to raise your ride height.
Bandit517
That Trials Guy
Wauseon, OH
As Chopperman said, adjusting the ride height sensor parameters is the only "right" way to do what you're after. It's how I leveled my truck. I used the daystar pucks and went into AlfaOBD and messed with the preset measurement until I got it where I wanted. Another option is to set the truck to Offroad2 setting, then after the truck is raised you can pull the fuse for the air ride.
