Air ride shop recommendation
barry hanna
Atlanta, GA
Looking for an independent shop in the Atlanta area that can diagnose and repair the air suspension.
Bandit517
That Trials Guy
Wauseon, OH
What's the symptom with it? As far as repair shops go, it's hard to find someone that'll properly diagnose the system. Most every case I've read about air suspension was filled with a ton of new parts, a hefty bill and lastly a suspension that still doesn't work as it should. If you're even remotely mechanically inclined, it's a good start to check the system for leaks. Remove the protective boot off all 4 bags and spray them with soapy water. Same for the distribution valve (and the hose connections). You'll likely find yourself with a far cheaper repair than a shop just throwing (expensive) parts at it blindly.
zrock
canada
i agree with the above comment it seems that their are no or few shops that will diagnose properly without just throwing parts at it until they find the issue. Also to go with above and looking for leaks put the truck in off road 2 so the bags are fully extended, i have seen issues were leaks to not show up until they are in one of the off road settings..
Daw14
South Florida
Evacuate and refill with fresh nitrogen every year. Moisture kills ,freezes .
