Air suspension gets hard by itself
Grrut
Se az
My 2015 1500 will all of a sudden start to ride extremely hard while I'm driving. I don't hit any button or switch but it changes. It has air suspension. Bounces me around pretty good. After parking it for a while it returns to normal. Any thoughts?
CanuckRam1313
Ontario Canada
2023 Warlock
Remove the factory air suspension components and upgrade to a better "standard non-air assisted suspension" ;)
The factory air rides are known to be typically fraught with issues (although not all of them), and correcting those issues can be costly, too!
G
Grrut
Se az
What replacement shocks areceady to switch over to? Will i need to do something to the computer after so no codes or warnings occur?
zrock
canada
Shut your areo mode off and see if that helps. THe wrong shocks could have been put in at some point or the truck is dropping to low and riding on the bump stops. That mode does not save you any fuel anyway it actually uses more i had tested it several times and always got better enon in normal mode
