Air Suspension or lowering the truck.
Xiayu
Toronto
Hemi V8
Hey guys,
New truck owner and probably made the stupidest mistake when purchasing.
I bought the 2019 Ram 1500 Big horn with 20 inches wheels.
I live in a condo with underground parkade that has a clearance of 6.2. The truck goes down perfectly fine.
The new issue is with my new business im required the use of ladder, so I need to install a ladder rack and travel with ladder, which going to be a trouble going in and out of the parkade.
Will you guys recommend getting a air suspension? or should i just fully lower the truck down.
thanks in advance!
Nickels
Mt. Howell, CA
5.7L HEMI
Air out the tires.
Im jk. Maybe try the rear lowering springs? lower profile tires too? I guess the air suspension would be the last option.
Uaintlo
It really comes down to how much $$ are you willing to spend.
A simple drop is a lot cheaper and easier to install then any air suspension system would be.
DwnDak
Ontario, Canada
A simple drop would be the answer, but I don't think with a ladder rack and ladder you are going to get the drop you need. Time to just park outside. Unless you want to spend $10k+ cutting up a brand new truck to add air ride.
BWL
Embrace the skeptisism
BC Canada
6'4" is damn low and the ladder rack with ladder has to add at least 6" to your height. I'd move.
