Air Suspension system part 3
Norman Roach
Canada
Dodge Ram Air Suspension System 2
1. Computer air suspension module controls the system by measuring each wheel sensors for the position selected. It switches reversing valves in the compressor to go up or down. It controls each port on the valve body, incomming air, and to expelled pressure and all 4 wheels.
The computer also monitors system pressures, and air compressor temperature and cycles it to cool it down if needed.
2. You need the air suspension tool and software to get codes and to change settings for doing purging and various other functions. The tool will give you faults that you can check such as leak right front air bag, but that could be at the valve body, the line, 90 degree elbow, bag valve or the air bag.
I did not find a description of the computer software of what else it can do.
Reticle918
