IceyTys
- Jan 24, 2023
- 11
- 0
- Location
- Dallas
- 2020
- 5.7L Hemi etorque
I hoping someone can help me out....I am trying to read my pin on my 2020 Ram 1500 limited using AlfaOBD and each time I run the procedure I get a error message. (See pics). I've tried doing it with the Ignition in the ON position (engine not running) and I even followed the instructions on AlfaOBD that says to try it with the ignition in the off position if the process fails.
If I do it with the ignition in the ON position it starts reading the RFHUB, but then about 30 seconds into the procedure it shuts the truck off completely and I get the error message afterwards.
If I do it with the ignition in the Off position it starts, then simply fails.
I am using a gateway bypass and it connects without issue to the RF Hub, so its not that.
Any help is greatly appreciated.
Thanks
Thanks
