AlfaOBD | Issue with Transferring Secret Key
thatguyx100
Panhandle
Hey all,
I have a 2007 Dodge Ram 2500 with the last of the 5.9 Cummins.
Been having a weird issue with the security system and I am hoping that it's the WCM going bad.
After installing the new WCM I use alfOBD to transfer the secret key from PCM and receive a - "failed. Conditions not correct or request sequence error."
I'll get this error when trying to do anything in that section related to needing the PIN, so transferring secret key to PCM or trying to reprogram keys.
This issue isn't experienced with the original WCM.
Although sometimes I'll get an issue with current WCM that says PIN incorrect even though I am using the correct PIN.
I'm thinking that has to do with the WCM failing though?
Any help on this matter would be appreciated.
