Alignment sheet good?
Ram7081
Hurricane 3.0
Alignment sheet look ok?
F: ICON coil overs set at 2.0". R: ICON shocks and TTL-1210 coils on 285/70-17 Yokohama's.
Massachusetts
Ive copied the specs for the truck below, all of your specs are within these ranges. Looks good to me
CAMBER - LEFT
0.10°
-0.30° to 0.50°
CAMBER - RIGHT
-0.10°
-0.30° to 0.50°
CROSS - CAMBER (Maximum Side-To-Side Difference)
0.20°
-0.20° to 0.60°
CASTER -- LEFT
3.50°
3.00° to 4.00°
CASTER - RIGHT (20 and 22 in. Tire)
3.90°
3.40° to 4.40°
CROSS - CASTER (20 and 22 in. Tire)
-0.40°
-0.80° to 0.00°
CASTER - RIGHT (17 in. Tire)
3.75°
3.25° to 4.25°
CROSS - CASTER (17 in. Tire)
-0.25°
-0.65° to 0.15°
TOE - TOTAL*
0.10°
0.00° to 0.20°
Positive toe (+) is toe-in and negative toe (−) is Toe-out.
* TOTAL TOE is the sum of both the left and right wheel toe settings. TOTAL TOE should be equally split between each wheel on the same axle to ensure the steering wheel is centered after setting toe.
REAR ALIGNMENT
PREFERRED SETTING
ACCEPTABLE RANGE
CAMBER
-0.10°
-0.60° to 0.40°
0.00°
-0.50° to 0.50°
TOE - TOTAL*
0.30°
0.00° to 0.60°
THRUST ANGLE
0.00°
-0.30° to 0.30°
Ram7081
Ram7081
Hurricane 3.0
Thank you Sir!
