All gears act like Neutral - Transmission
Tolin02
Was doing some donuts and all of a sudden truck just rolled. Turned it off and later came back to it. Starts right up, but Drive, Reverse, and low gears all act as neutral. Transmission oil looks fine and no clunking noise.
Any thoughts? Truck is a 2006 Dodge Ram 1500 2wd Hemi. Torque converter replaced last March.
rzr6-4
nebraska
'09 2500
Like the others are saying you done messed something up. Not going to be a simple fix, probably a full rebuild. Stupid is expensive.
Pull it out and get to work or get the wallet out for someone else to do it.
tron67j
Maryland
Like when my friend and I finished a rebuild of the transmission on his 65 Chevy and then we dropped the jack, did burn outs, and fried the rebuild after an hour? Fortunately, we kind of outgrew some of our stupid because it expensive.
Belvedere65
Alabama
2005 Ram, doing 40 mph and trans quit pulling, pump had quit pumping. Put a reman trans in.
Marshall
Sk, Canada
2014 sport
If you have to ask here, don’t no donuts, I just buy mine at the co-op, with sugar , cost way less.
I was going to say also, check drive shaft to see if you took the rear end out.
southalum
