All Repair Parts @ Employee Cost!
Tim West
Hello I need to replace a couple plastic pieces. I need the plastic bed caps for the left, right, tailgate, license plate lamp housing left/ right and the circle round piece that covers the hole where the trailer ball would go. (I just replaced the bumped step pad and all the other pieces look bad next to the new bumper pad.
VIN 1D3HV16PX9J521580 (09 RAM 1500 4x4 single cab slt)
Thank you,
Tim
Lawsuit11
Westland, MI
Quote for
8.4 Single Zone MTC Bezel for 2018 Ram 1500 PN: 1UJ96DX9AJ
HVAC module PN: 68366552
AllMoparParts.com
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi Paul, I replied to the other post and sent PM
Thank you,
Benny
TMyers
USMC 84' - 92'
north wilkesboro, nc
Cummins 6.7
Hey Benny,
Can you help me find a part? It's the center cap for a '18 2500 Laramie 20" wheel. It's the satin finished one. The chrome part is #4726280AA. Thanks!
sdwalter
Wisconsin
Hi Benny -
I have a 2017 Ram 1500 SLT and I would like to order the following:
Cabin Air Temperature Sensor (Is it 68138681AC or 55111178AC?)
Temp Sensor Harness (part number unknown)
Humidity Sensor (55111389AF)
Humidity Sensor Cover (1SU12DX9AA)
Humidity Sensor Wiring (68207371AD)
Thanks!!
Scott
Lawsuit11
Westland, MI
Quote
OEM Key Fob for 2018 Ram 1500
Vin - 1C6RR6GT8JS105124
Thank you Benny!
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hey Benny,
Hello,
Yes I believe it is 5RK12DD5AA
I pulled the part number from this vehicle's wheel
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hi Benny -
Thanks!!
Scott
Hi Scott,
It should be 55111178AC for that Year/model
I just want to clarify the harness you need is it for the humidity sensor? (overhead)
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
sdwalter
Wisconsin
Hi Scott,
-Benny
Hi Benny -
I need two harnesses. One for the overhead humidity sensor and the other for the cabin air temp sensor.
For the cabin air sensor, I installed the infotainment radio upgrade kit and the harness has a connector for the temp sensor. I assumed that means the factory temp sensor harness will connect the sensor to this harness. If that is not correct, I will have to buy a harness from M2.
I hope that makes sense. I could not find a parts diagram that shows the wiring harnesses to confirm that is what I need.
Scott
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hi Benny -
Scott
Hey Scott,
For the overhead harness I need your VIN to see what current options you have ex. rain sense wipers, auto dim etc.. as there are many variations
For the temp sensor I am taking a guess here and assuming it's part of the AC/Heat harness. Have others reported swapping out this harness to perform this modification?
Here is an image of that harness
-Benny
sdwalter
Wisconsin
Hey Scott,
-Benny
Hi Benny -
Thanks for all the help. The temp sensor harness is not what I need. It looks like they added a connector to their harness for a custom cable. I will get what I need there from either infotainment or M2.
The VIN for my truck is 1c6rr7tt2hs533762. I just purchased a rear view mirror with smart beam and autodim, so I am looking for a harness that will connect those two features along with the humidity sensor. The VIN that the mirror came from is 3C6JR6DT5JG204394 if that helps.
Is there a site online where I could look this up without asking you to do all of the research?
Scott Walter
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hi Scott,
Thanks for the donor VIN it is very helpful. The harness you need is 68343005AA and can be purchased here
https://parts.allmoparparts.com/oem-parts/mopar-wiring-header-68343005aa
Most online catalogs as with ours are from a 3rd party and when it comes to very late model parts can be a bit weak and if you are performing a mod then they are pretty much useless.
Feel free to PM me anytime with any inquiries,
Benny
SkunKd
Wilmington, DE
NONE
NONE
Hello,
Looking for a price quote from you on 2 Radio Replacement Parts for my WK2 Grand Cherokee:
(1) 68331631AH (looks like the new version is 68331631AI)
(1) 68323663AD
Thanks!
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hello,
(1) 68323663AD
Thanks!
Sure these prices can be found here
https://parts.allmoparparts.com/oem-parts/mopar-radio-multi-media-68331631ai
https://parts.allmoparparts.com/oem-parts/mopar-connector-hub-68323663ad
The radio is on a slight backorder so it can take a week or 2. I will send you a code you can use
-Benny
Lawsuit11
Westland, MI
Benny im doing the converison to Power folding mirrors on my truck can i have the below part numbers for this setup and anything you know i am forgetting
Drivers window switch with one touch up & down and power folding(quad cab)
power folding mirrow module both doors
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Sure , Here you go
56046826AE
68225103AC
68225102AC
-Benny
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Benny I have a couple of questions if you can answer them. I am looking to get a stronger efan for my truck. I know that I have the 55056948AI. Would you know if the 52014772AF is a better cfm fan than what I have or would 55056851AG be better? Also do you know if the 68217820AB fan would bolt up to my radiator and would the plug also be the same? Also are you running any discounts at the moment?
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
I wish I had some answers for you but we do not have engineering data to compare CFM nor can we confirm fitment as this combo of a 5.7 Rad and 3.0 Fan never came from the factory.
I will message you a code you can use if you wanted to place an order.
-Benny
