All Repair Parts @ Employee Cost!
SouthernGorilla
Arlington, TX
The shifter has gone out on my '04 1500 Quad Cab 4x4 with the NV3500. Probably need the whole shift tower assembly even though I'm assuming it's just the plastic bushing on the end of the lever. Haven't pulled it apart yet to check it out.
VIN# 1D7HU18N04J202856
AllMoparParts.com
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
SouthernGorilla
Arlington, TX
The lever 52107787AA itself appears to be all metal from the photos I could find and is most likely not the issue
The shifter assembly 4886199AB has been discontinued however I did come across this one which shows to be a replacement https://core-shifters.com/products/...dge-ram-truck-w-nv3500?variant=22156272697462
Please let me know if you have any other questions.
Thanks,
-Benny
Yeah, the lever is fine, it's the housing that's broken. The Core one is out of stock and I can't get anyone to tell me when or if it will be back in stock.
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
I hear ya, Try searching the OE part number 4886199AB for other results. I saw a used one on Ebay.
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Thanks, I sent you a code you can use
-Benny
genosguy
Broadway, va
3.6 ltr
Not sure how long this is going to last but if your in need of Genuine Mopar parts now is the time https://www.allmoparparts.com/repair-parts.php
Please reply here with any and all inquiries and I will be happy to quote for you :)
Thanks,
Benny
I need a mating connector for the Uconnect
Thanks,
Benny
I need a mating connector for the U-connect (maroon color) connector on the 8l4 nav/uconnect/ am/fm/xm radio/display on a 2014 ram 1500. Can you give me the part number or provide the parts (3 parts to that connector a ferule center pin, housing. It's at the end of the harness give me a PM or reply to my email address
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
I believe this harness to be part # 68148260AC , You cannot just purchase the connector for these through Mopar
-Benny
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
Hi Benny,
I recently purchased an autodimming rear view mirror from a 2017 for my 2018. Trying to install it last night, I found that the trilobe bracket from my 2018 mirror base that twists onto the bolt head on the windshield would not fit into the base of the 2017 mirror. Well, it WILL fit if filed down enough. But then, the 2018 torx bolt that holds the bracket in the base is too small.
Do you know if the 2017 bracket and torx bolt can be bought by themselves, or does it only come as part of the whole mirror assembly?
Parts diagram
Thanks.
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hi Benny,
Parts diagram
Thanks.
Hi,
I am sorry but I do not see any serviceable parts. The button on the windshield only comes with a new windshield and the mirror shows no components.
-Benny
RodeoRam
North Carolina
Hemi 5.7 2500 CC
Hi,
-Benny
That's what I figured. So, I guess I will need to buy a new or another used mirror to get the parts I need. Do you know if the bare bones mirror P/N 57010393AC will get me there? Your price is pretty competitive with the junkyard prices I've found so why not get a new one from you?
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Thats a good question, I suppose it depends on if the one you have has the same screw which can be removed as shown below
What is the part number of the "new" one you received?
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Would you have a ram bed divider?
I am sorry but the Mopar divider part # 82211493 has been discontinued. You can try contacting the dealer below as they show one in stock however please note bed rails are required for use with this
PEARMAN MOTOR COMPANY ALTO TX USA Phone: (936)-858-4979
Thanks,
-Benny
