Alloy wheel cleaning help???
bronx79
Montana
So living in Montana in the winter is rough on my wheels.... Especially the rear wheels. they get stained and darker than the front and they get really really hard to clean!! Any of you know a good cleaner or rubbing compound i can use to get these clean and then is there a way to protect them in the future??
Stangshcky12
Oshkosh, WI
5.9 Cummins
Ate they an aftermarket aluminum wheel?
Your best bet might be to get rogue polish and a buffing wheel come spring time and put a nice wax on them after
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I have had great luck with a mothers powerball and their aluminum polish. Once you get them clean, you can either have them clearcoated, or apply multiple thick coats of wax on them to help protect the finish.
bronx79
bronx79
Montana
Yes they are after market aluminum rims. so is there a better wax for aluminum?
Chewy
Bettendorf IA
V8
Use a sealant for your wheel protection. It handles the dust, heat and road grime MUCH better. I recommend Adams Quick Sealant. Check out Adams Polishes metal cleaner #1 & #2 if you want nearly chrome results. Amazing!
Sent from my iDevice using data nodes and algorithms.
bronx79
bronx79
Montana
So use the sealant after the adams 1 and 2 polish?
Chewy
Bettendorf IA
V8
Correct! Check out YouTube for how to vids or go to adamspolishes.com where there's vids or Adamsforum.com for more help. 110% guarantee and the best customer service I've seen in the industry.
Cedar Plank
