Alpha OBD Alternative?
04RAM_3
CA
So Alpha OBD works on newer trucks, but not my 04. Is there anything like it for the older trucks like mine? Anyone know?
CanRebel
Toronto
jscan says it works for 2006, you could try the free version see if it will do what you need.
04RAM_3
04RAM_3
CA
I already have it. Tried it for fun. 2004 is not an option. There's no canbus so it won't work
HemiLonestar
Navy Badge Coast Guard
MD
No, because PCI bus doesn't work that way lol. There is no turning stuff on or enabling it. Just out of curiosity, what were you hoping to do?
That's because your truck has CAN (first year in Rams for it) but even then is limited.
Dean2
Near Edmonton
Your options on vehicles of that age are heavily dependant on what it is you are trying to do. They were controlled completely different than the vehicles of today.
04RAM_3
04RAM_3
CA
I just wanted to play with it. Thanks for the replies
HemiLonestar
MD
The best you can do is get a DRBIII or compatible scanner and you can do stuff like change some user settings (light duration on shut off, horn honk, etc) and use it for diagnostics and/or a quick learn when you eventually have to replace your RFE.
