Electric radiator fan temp control
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Trying to find a way to change the temp when the electric cooling fan comes on in my 2017 Ram 1500 3.6L pentastar.
Does anyone know if this can be done with Alfa OBD?
If so, can you please point me in the right direction to change it?
Thanks in advance for any help!
RamDiver
Marlborough, Ontario Canada
2021 DS
That sure would be great, if that were an available option with AlfaOBD, but no.
The only way to accomplish this electronically is with an unlocked PCM and a tune.
If you search the threads, you will find discussions on this topic.
HP Tuner is the current preference.
@Mojo88 has experience with this tweak using HP Tuner.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
AlfaOBD won't do it.
To change the temp for the fan, you will need a tuner, or something similar that can change the PCM / ECM programming.
Your truck is a '17 and will need an unlocked ECM also, which is usually done by vendors like DiabloSport or HPTuners. Not for skinny wallets.
04fxdwgi
2016 1500 Sport
LOL. You hit send button while I was typing.
tnctx02
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Thank you all for your responses.
After reading these, I have been looking at removing the fan and adding an aftermarket dual fan set up that I can set my own temps on.
Still investigating them.
Thanks again
Johnnguyen6596
