AlphaOBD air suspension help needed!!
Keith newc
Canada
So I tried to adjust my suspension with the AlphaOBD app and its been a disaster. I had no problems running the app, running diagnostics or performing tests but as soon as i tried to adjust the height values the app crashed. Now i am stuck with no values at all. The truck is stuck somewhere between entry/exit and normal mode and all the "up/down buttons are flashing. Im getting the "service suspension system immediately" message on start up and the air won't work at all. When i try to test the values it tells me it is not calibrated, when i try to calibrate it, it crashes. I can run the sensor test and it will do it up and down thing and all lights will stop flashing and stay solid but as soon as i touch one they start flashing again. I've pulled the neg battery terminal and that did nothing. I don't know what to do next.... 2017 Ram Rebel.
MrDazana
Hi, hopefully you got your settings back. If you hadn't these are the settings i see most often in truck with the air ride 54/53/54/50 (FL/FR/RL/RR)
If you want about a 2 inch lift go with these settings 85/70/68/55. you will need a wheel aliment after
1500ram12
5.9L Cummins
When connected to the bcm click on the check engine icon and clear any codes. Wouldn't hurt to connect to the engine and rf hub and check them also
2018 Ram 2500 6.4L Hemi Tradesman
DaveSharp
Canada
Did you get this fixed? If so what did you do?
Austinv
