air bag suspension
  1. L
    2013 Ram 1500 - Rear air suspension sensors
    Rear air suspension sensor data inverted! LF:90mm RF:68 LR:-47 RR:-41 Fender height= Fronts:39” Rears:37” Currently the truck is stuck in off-road 1, initially the trucks code weren’t showing sensor errors it was showing error:U0422 and would time to time allow you to set the ride height. I...
  2. R
    2024 ram 2500 Uncontrollable Trailer Sway
    I have a brand new 2024 Ram 2500 Crew Cab Laramie with the air bag suspension (Christmas Present!!). At 842 Miles I towed a 16' loaded car trailer (10,000#) w/hydraulic brakes. Hitting a bump, just before a curve, caused the trailer to sway uncontrollably resulting in a jack-knife into a fence...
  3. B
    Service air suspension, electronic braking system? 2017 ram rebel
    I got an alignment and when I left my service air suspension system and electronic braking system came on at the same time and my traction control is stuck off but I left my truck off over night and my air suspension never dropped or lost air it is still at normal ride height, the fuses/relays...
  4. StruggleBus
    Upgrade combos for towing and every day driving.
    So I’ve been searching thru the previous post on here for a couple days and I think I may have pieced together the answer thru a few different threads I just want to make sure I’m understanding this right. I have a 2022 Ram 2500 Bighorn w/ a 6.7 and we really like it. Only complaint is ride...
  5. N
    Air suspension settings
    Hello all, I have a 2015 RAM 1500 laramie limited with air suspension. Is there a way to set the hight options to lowest hight setting when the unlock button is pushed?
  6. H
    Air suspension leaking smh
    The air suspension in my truck is leaking and I’m looking at replacing it with a lift kit. Do I need anything funky to make it fit or is is just fine be the warning lights staying on causing me issues? Is there any programmer that can remove them permanently?
  7. A
    Air suspension
    First time on the forum. So here we go, I have 2016 sport with air suspension and shocker, I’m having problems. We figured out the problems, a bag had leak and in result to that it burned up a compressor. 4 grand to fix it, so I decided to go with a delete instead. But I was wondering if a lift...
  8. J
    lifting 2016 rebel w/ air suspension
    Really wanting to swap out air suspension on my rebel with standard standard shocks, have been bottomed out all winter and dealership won't do anything. I figured if I have to pay to swap suspension I might as well lift while I'm at it. was wanting to do a 6 inch lift if possible but wasn't sure...
  9. Articlonestar
    Air ride replacement help
    Hey everyone! Happy new years! I have a 2015 ram 1500 quad cab with 4x4 and active level air suspension. I have had the dreaded sag whenever I park and finally but the bullet and bought all 4 new air bags and compressor with valve block. I purchased the springs from TRQ as it wasn't a bazillion...
  10. RodRamCar
    4th Gen Limited - Lets see 'em!!
    Hello, as a pretty new member with a new to me truck, I wanted to see everyone's 4th Gen Limited and mods or dealer add ons you went with so I will start: 2017 Limited 4x4 5.7 60k miles Color: True Blue Pearl Crew Cab Factory Chrome Running Boards Bakflip Fibermax Tonneau Toyo Open Country A/T...
  11. Smyers486
    Air ride compressor failure
    Hey guys, looking to see if anyone else is having issues with their Air ride? Just purchased a 2019 Ram 1500 Limited back in October and when cooler weather began to roll in, I noticed the truck literally looks like it's doing the downward dog yoga position.. took it to ram dealership 3x only...
  12. Plankton
    Air Suspension Deflate
    I have a 2017 Rebel with the air bags. I've noticed that after letting my truck sit for a day or so the front end drops all the way down. Just the front. There's no codes or anything and fills back up after starting it up and everything is as it should be as far as I can tell. It's happened...
  13. S
    2016 Laramie 1500 Air Suspension/FCA warranty service nightmare - Any advice?
    First post; coming here to see if anyone has had similar experiences because I'm at my wit's end with this situation and I'm hoping someone here may have successfully navigated similar issues, or might have general advice on what route to escalate the situation next. Many thanks in advance to...
  14. Timmy B
    Air Ride suspension with bed rack and RTT
    I'm looking at getting a Rebel with Air suspension, I plan to add a bed rack and a roof top tent, and other overlanding accessories onto the rack. Anyone know how the air suspension will hold up with this constant added weight? Thanks!
  15. B
    Level Tow by Ride Tech install
    Ok gents as I start the planing the install of my rear air ride by Ride Tech. I need some. Ideals and feed back from anyone who has this system. Like where you mounted the leveling switch and compressor? I know it’s not factory stuff but I want to make it look like it belongs. I plan to wire it...
  16. Tuna
    Rear Brakes
    Haven't been on here much, but I have s 2013 Ram 1500 that I have bagged and narrowed the rear axle. My problem is the rear brakes are hitting the frame rail and I need to rotate the caliper down or under the disk so it doesn't hit the frame. Does anyone have any experience with this or know...
  17. Keith newc
    AlphaOBD air suspension help needed!!
    So I tried to adjust my suspension with the AlphaOBD app and its been a disaster. I had no problems running the app, running diagnostics or performing tests but as soon as i tried to adjust the height values the app crashed. Now i am stuck with no values at all. The truck is stuck somewhere...
  18. Intense-Dakota
    First long haul w/ 4K lb - Engine/Trans Braking in mountains?
    I have had many trucks through the years, and about 6 months ago I replaced my 2014 2500 with a 2017 REBEL (5.7L, 8 speed, 3.92 4x4, CC, Air Suspension). I have towed a lot, but all usually within 20-30 miles, and never through the mountains. I have driving Pike's Peak and Mt. Washington so I am...
  19. chasles22
    3.21 gear change and other towing upgrades.
    searched around a bit and can't quite get at what I am wondering. we are thinking about buy a TT and also have a boat we would like to trailer sometimes. I have a big horn with 3.21 gears which will tow ~8200lbs. no other change (same transmission, same trans cooler, same everything) with 3.92...
  20. Seawri
    Air suspension, air spring, timbrens?
    Whats my best route for leveling my truck with payload? Would a air spring do the trick or should i go with the air suspension? I like the timbrens easy to install and i dont have to worry about air pressure but am i going to feel a rough ride while under load? I may have heavy loads in my truck...
  21. DSO1977
    Air Suspension Warning
    Wondering if anyone has seen their Air Suspension Warning ⚠️ light come on? Mine has come on a few times very quickly, then shut off? I have about 4,500 miles on the truck and haven’t been in yet for the first service. Thanks
  22. tourrider
    Oh Look what UPS just dropped off!
    I guess I have something to do tomorrow after a dump run, and closing the pool!
  23. MillerTime802
    2016 Ram 2500 Air Bag Rear Suspension, 4 Wheel Drive, Laramie Longhorn.
    I have an overload icon that periodically appears on my dash when towing my toy hauler. I took the trailer specs to the dealer when i purchased the truck and they said i'd have no issues pulling the rig. I consulted with the dealer after the warning light first turned on, they checked out the...
noraa73
