Alphaobd issue
WarlockMan
Alberta
So, here’s my issue. I changed basically every light to an LED in my Ram. Exterior and interior. I was messing around with alphaobd and now, when I open my doors the interior lights don’t come on. Only when the key is in the ignition does it work. I’ve read a few threads and seen some information about the door ajar settings. I’m looking for the original settings.
And no, I didn’t make a backup before I made these changes.
indept
South Jersey
Welcome to the forum. Can't tell you what setting it is but you should be able to find the answer in the AlphaOBD sticky below, do a search there:
W
WarlockMan
Alberta
Well, I fixed it. It wasn’t a matter of using Alphaobd. Turns out one of the LEDs in the interior was dying (on its way out). I replaced the upper glove box, dome, map and feet LEDs. Now it’s working as it should. I went with error free canbus LEDs and they seem to work fine.
Raadz
