Alpharex Pro G2 - Parking Light Out - help needed
Yazen
Columbia Missouri
So a year ago, I purchased alpharex G2, i got parking light out message, contacted alpharex, they sent me resistors, installed resisters, message went away until a month or so ago.
I contacted alpharex, they sent me new resistors, I replaced them, parking light out messages never went away, I cleared it with alphOBD, nope still comes up every time I break, or use right/left signals.
I thought they must have sent me the wrong resisters, so I bought a set from AutoZone, Sylvania LED Load Resistor. Same issue!
About a week ago I changed left/right turn signals, parking/marker lights to LED in AlphaOBD, cleared all error codes, but I still get the error message and a ding.
It is driving me crazy! Not sure what else to do. Any advice or recommendation is highly appreciated.
Thank you
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Thank you
You are SOOL homie ... I got the same thing when I bought some Alpharex headlights myself too... they were no help .. crappy company that doesn't care about customer service .... they have no clue, they have no solution, why? They don't make their headlights here, they are made overseas and have no understanding of the internals of these headlights ....
My truck is a 2018, I am seeing this happening to a lot of trucks the same year or newer ... there are also some older trucks, but these trucks just don't like any interruption to the signal lights, side markers or the drls ....
In ALFAOBD there is no setting for the parking lamps which is what "I" think is causing these errors ...
I just installed some ANZO USA headlights, well exactly a month ago now, I got them October 10th ... this whole time they were working fine, they need 3 resistors, one for the drls, one of the highs, one for the lows ... I didn't get single light out warning until about a week ago ..
I removed the resistors, switched some settings with ALFAOBD and it's been good so far....
If you have ALFAOBD you can change a few settings around that might help your situation ... I wouldn't even bother with AlphaRex, they are useless ...
Yazen
Yazen
Columbia Missouri
You are absolutely right about Alpharex. I spent 52 minutes talking to them, they have no clues! They suggested I replace the low light bulbs!! What!!? Are yiu kidding me! That has nothing to do with the parking light out!
Any suggestions on what else to switch to LED in AlphaOBD?
I am stuck and don't know else to do! Very frustrating!
Thanks
2018 2wd
Thanks
If you can maybe post your backup file I might be able to see what you got that you can possibly change ... I went through a few setting combinations until I found one that seems to be working now ...
Believe me, I know how you feel homie .... I will try and help you as much as I can ... if you are not comfortable sharing your back up file here, send it in private message
Yazen
Yazen
Columbia Missouri
Thank you brother. I will get a new backup in a few and share it with you.
2018 2wd
Be prepared to remove the resistors and try it out with the settings I think might work ... Like I said, I removed all the resistors, switched some settings and bam so far so good ...
2018 2wd
I am going outside to quick detail my truck and the wife's Lexus, I should be back in a couple of hours .... but I will check in on the thread in between all the detailing I am doing ...
Yazen
Yazen
Columbia Missouri
I did a new backup, but having difficulty opening it on my phone. I will share it in a couple of hours when I get home.
Oh I am ready to try anything!
Yazen
Yazen
Columbia Missouri
Oh I bet homie .... I should be done here in about another hour or so ....
Guess what! I left work and thought I'd make some more changes in AlphaOBD. I changed low, hi beams, break lamp, rear turn signals all to LED, then cleared fault codes, removed battery terminals for about 5 minutes, reconnected terminal, and OMFG I did not get any messages driving all the way home!!
I am hoping this fixes it. Still gonna share the settings with you here in a moment as I just got home, need to fire up the computer and send yiu the file.
2018 2wd
There you go !!! ... I had to switch my rear lights all to LED as well too ... that I kept getting them and the last rear lights I switched to LED status was the rear turn lights I think and after that no more light out warnings lol ...
Irongoats
Las Vegas
She gone 2015 Sport
I am having the same problem. So, if I'm reading this correctly in Alfa change all lights to LED?
brianw0048
EcoDiesel
I have the g2 2500 style, just installed them this week. I have HIDs in the low beams and installed Fahren LEDs in the highs tonight.
Everything is set to HID/LED via alfaobd and I’m getting no error messages.
Cumminnotstrokin
6.7 diesel
Has this still been working for you?
KwyjiboJonesJr
