Amp Research Running Boards
DDH67
TN
Are the amp research running boards still having issues with the pinch welds on the 2018 RAM 2500. I really don’t want to modify my pinch welds to accommodate these running boards. I am willing to modify the running boards though. Anyone else know of any fixes without modifying the pinch welds? I know RBP has a set of running boards but I don’t like the magnet concept they have.
Thanks
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Thanks
Every Truck is different. Nothing better than amp steps though. the rbp hang down. Get the Amp XL series if you dont want to risk having to trim
oe542bob
Hemi eTorque 5.7
I put them on my 2018 Ram 2500. I had an issue on my passenger side. It went up no problem, but got hung up trying to extend. After I got it back to the extended position, I loosened up the mounting bolts a little and basically really put my weight up and down on the running board. I then snugged up all the bolts again and then it worked perfectly.
When it 1st happened, I thought I would have to trim the pinch weld. Drivers side gave no trouble at all. Oh, and I did put my weight on both sides initially.
My truck is stock height, and the boards are extended just about perfect. Getting the XLs, which I think extend 3” more, may be kinda awkwardly low.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I heard install them, and when down, pretty much jump up and down on them, you get the pinch weld straight. Most Ram/Amp are that way, from my local dealer that does all the Ram upfitting for local dealer.
Ricks Ram
I've installed 4 sets on 4th gen 1500's and have never had to trim the pinch weld. I had one that pretty much cleared with a little adjustment and the other three took a little more work lightly bouncing ( without actually having your feet leave the step) but they all eventually settled in. Ironically my truck was the most stubborn.
Sent from my SM-G981U1 using Tapatalk
D
DDH67
TN
Thank you for the replies! I think I’m going to go ahead and order them. Worse case I return them.
Graygoose
Oklahoma
Convert, for now.
small
You will love em!
Nick@GotExhaust
Preferred Vendor
SC
As stated, Install them but dont full snug them up and stand on the steps, even lightly bounce on them. Then snug them up and it should be fine. Let us know if you would like a quote on them. We stock them and offer great pricing. Just send me a message if interested
Orca
