PowrRam
- May 12, 2018
- 774
- 631
- Location
- Minneapolis
- 2018 Big Horn
- 3.6L V6
2018 Big Horn with stock six speaker 8.4 UConnect.
(BTW, this is not the usually reported problem with the Google Assistant voice being unusually loud and unable to be reduced in volume.)
I had occasion to use Android Auto recently after a couple of months of not needing to use it. Up until now it has worked as advertised. However, when I use it now, when Android Auto turns on it hijacks the stereo's controls. The stereo's volume control is either muted or else the volume level is frozen at whatever setting it was at before AA was engaged. Turning the volume control has no effect. Another time I had volume control working but only had the right audio channel, no left channel. I also noticed when any of these symptoms appear when AA is engaged, my graphic equalizer is set to flat tone control and cannot be altered and the balance/fader control is unresponsive. Basically when AA is engaged the stereo volume and other controls are not working. I am able to change input sources, that is, I can switch between FM, AM, and USB inputs.
Things I've tried to fix it:
* Swapped USB cables
* Swapped USB ports
* Removed USB flash drive (music) from USB port
* Uninstalled/reinstalled Android Auto
* Checked and confirmed proper settings in AA.
* Power cycled my phone off/on.
I found a workaround though. If I tap on the Google Assistant microphone icon in the lower right hand corner of the AA touch screen and then tap anywhere on the touchscreen I regain control of the volume (and all other stereo controls.) So, apparently engaging Google Assistant resets something internally which enables the stereo to be controlled by the user.
Anyone else experience this loss of control of the stereo when using Android Auto?
Any explanation as to why this is happening?
I did have the battery replaced about 3 weeks ago but don't see how that could cause this problem.
Is it possible an update to Android Auto caused the problem?
* Swapped USB ports
