Another LED issue
Jon A
Thornton Co
Installed the Alpha Rex headlights everything was cool. Then I upgraded the low beams with the Hikari Ultra's, then it went bad. The light will only stay on for 10 to 15 seconds then go out. I used my Alpha OBD and changed my low beam setting to recognize the LED. The turn signal and the High beam are both working flawless. Bad bulb or missing something stupid?
kurek
Northwest
It's not an upgrade if it's worse :D
I believe a few others have had to set the BCM for having High Intensity Discharge headlights using AlfaOBD. Did you use LEDs in the highs also?
Report back your findings
J
Jon A
Thornton Co
Yes I used Auxbeam LED's for the high beam. Those are working just fine.
Arcangel06
Need to set High Intensity Discharge Headlamps Present to YES to deactivate Pulse Width Modulation on low beams. Also Set LED low beams present to YES simultaneously.
