Another led question
tman1112000
Greeneville TN
hemi
Hey all ... Have a 2014 ram 1500 big horn installed leds all over and used
AlphaOBD to change everything too led .but im getting parking light out but only when lights are on and i hit the brakes the tail lights are​
OeMassive https://www.ebay.com/itm/176154733151 i contacted them and they said i need a resistor installed even though it has one . all lights work no flicker none cutting out just that parking light warning on dash
so my question is what resistors should i get or should i try too get them too send me some new ones that come with there lights . or send em back and get different ones
also 2 small leds in the side stay on for like 20 minutes after i turn truck off
David H
USA RET
Minneapolis
Seems I've read about this a dozen times. Some have success using the AlphaOBD set up to change the headlights to "HID". Might give that a try.
T
tman1112000
Greeneville TN
hemi
will try that but if i install the stock tails then no more dash light
David H
USA RET
Minneapolis
Got it. Free and easy to try the HID setting though it may not correct your truck's confusion with the tail assemblies. Good luck and let us know.
T
tman1112000
Greeneville TN
hemi
didnt help
anyone know what resistors too buy and how too wire them in ?
ricky_bobby
Wake County, NC
6.7L Cummins
There are several rear LED tail lamp settings in AlfaOBD for LED - you'll have to enable them all - I also believe the 2015 is the most finicky year for resistors on lighting et
T
tman1112000
Greeneville TN
hemi
ok after ordering different tails and some OEM sockets im still getting the parking light out warning ( when lights are on and brake is pressed only ) i have everything set to led in Alpha ( i think ) and help or suggestions would be wonderful ( i can reinstall oem tails and have no issues so in the leds for some reason also new set of tails use oem reverse lights thought i would take one possible issue outta the equation )
so after new sockets and about 30 minutes and clearing codes seems my issue is fixed for now will let everyone know in a day or 2
MoparFin
U. S. Navy Vet - AS1
PA
So you ended up changing the sockets and LED settings and that fixed it? I am having same issue.
Kraken
Also having this issue, would love to know what OP did exactly.
(Meaning, non-CAN bus friendly LED's in the rear tail/turn signal, with 6 ohm/50W resistors. Works fine until headlights are on, when it's dark I get a turn signal out error but no hyper-flash, every time I brake)
crcraft
