another trans fluid change question
Shawn Burns
Army Law Enforcement
Lewisburg, PA
2016 Rebel
For those of us that have caulk's bypass installed, what should the procedure be to check the level? It would take an hour of towing to get my temp to 122f. The last time that I changed it, I had to wait forever for it to get past 86f.
You can check it anywhere between 86 to 122.Read the temps on this sheet.122 is the max temp to check it at. Supposedly 110 is the ideal temp,but if your transmission is at 90,you're still with-in the checking window.
