Another wheel speed sensor problem Missing wire
Forest crumpler
mami
My right front wheel speed sensor has a cable that goes through the brake area to a connector (all normal) There is No wire from the connector to wherever it should go. I could fix it if I knew where it had been ripped out of. Can you point me to wiring information as to where this wire should go?
