Any tips on how to remove
Kcchief434
Mays landing nj
I removed all my emblems and waxed all the areas and it looks clean but the only problem was one spot where the heavy duty logo was underneath it's hazy any tips on what to do or do I just buy emblems and put them back on0fe18c8d2de24a11672fb86df70bda7f.jpg
Sent from my SM-J737V using Tapatalk
heat gun removes any residue, polish removes hazy clear coat, best results with a polisher and not by hand. Most polishes have diminishing abrasives, the need a polisher to work best. I can't see, is the clear coat damaged? If so yeah that is fatal, can't fix that with an product except more CC.
K
Kcchief434
Mays landing nj
I cant really tell all i did was pull the emblem and pull off residue with my finger and there was that lighter spot under where the emblem was
MADDOG
Living in a Firepit
It's cut and buff time.
If you can't get that haze off with some adhesive remover, then with some wax; get some light rubbing compound and polish the area. Then give it a good waxing after you determine if the rubbing compound took care of the haze.
K
Kcchief434
Mays landing nj
I used turtle wax rubbing compound. No luck. All the residue is gone its just a light area that was under the heavy duty emblem. Weird that the spot under the emblem looks faded. i thought it would be the other way around.?
MADDOG
Living in a Firepit
I would think it would look a bit darker than the uncovered areas around it.
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
To me it almost looks like not enough paint under the clear
