Any way to use non-OEM fender flares with mud guards?
620mac
Kansas
I like the look of fender flares, but I know generally you can only either have mud guards, or fender flares (non-OEM). I do have the OEM painted fender flares with Husky mud guards currently. Looking for something that stands out a bit more, and keeps a little more crap off the sides.
Stewi
I've seen aftermarket pocket style flares and OEM Mopar rubber mud flaps (the thick flat ones, not molded) and I've also seen people use the gator back mud flaps with pocket flares as well. I plan to use pocket flares and the MOPAR ones.
Mauzz
I hope someone chimes in as I will be in a similar situation once i get my wheels/tires on.
MADDOG
Living in a Firepit
6.4L HEMI
I'd suggest some universal fit mud flaps you can trim and drill to fit the profile of the flare at the top and then extend past the flare as it curves under the body panel.
I need to do this as well but haven't found any custom made flaps that will work.
