BlownGP
- Feb 10, 2013
- 6,082
- 1,573
- Location
- Houston/Baton Rouge
- 2018 RAM Harvest New Holland Blue
- 5.7
Keep us updated..
2013 and up use OAT which as of a few months ago only mopar sells the correct coolant. I found this out the hard way when I topped of with hoat after switching to a 180 tstat and had to do a complete flush.Yeah, older ones use HOAT.....
Was thinking maybe it's a different color but I don't think it should be brown.
I just used the same color coolant from autozone on mine. Zero issues.2013 and up use OAT which as of a few months ago only mopar sells the correct coolant. I found this out the hard way when I topped of with hoat after switching to a 180 tstat and had to do a complete flush.
Hopefully it's not a major issue and they don't try to say the tstat caused it. Goodluck!
It's my understanding that just because it's the same color, it may not be the same chemical composition and mixing coolants can eventually cause issues.I just used the same color coolant from autozone on mine. Zero issues.
A lot of my mechanic friends are saying it's oil from the picture. But they have yet to look at it yet. This impala rental though. ...
I know I'm resurrecting this thread, but that looked like an oil cooler failure if there is on one 5.7... What ended up happening with that?A lot of my mechanic friends are saying it's oil from the picture. But they have yet to look at it yet. This impala rental though. ...
This is what it stays at, sometimes a few degrees higher. My tuner reads the same temp as well.
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons make you fat...
I'm not sure there is any benefit to running the 180 T-stat on these newer trucks.
Years ago heat was your enemy on the older iron block / iron head engines, but all this new stuff is built to run between 190 and 210. If anything running 180 without a tune is going to have the ECU thinking the engine is constantly cold, so it will be adding fuel trying to warm up. When I first take off in my truck the temp will get up to ~213, then the t-stat opens and the fan kicks on, dropping it down to around 200. After that it stays between 195 and 205.
I would realy like to believe that. What worries me is our new trucks are so electronic. Computer and sensors all over. If I change out the factory therma for a 180* will it set up a interface issue. I did change to 180* therma in my 03 5.7. No issue other than it runs about 5* cooler. But that 5.7 is not the new 6.4.I've had mine for about 5 years never had any problems. And I've ran them in other cars for almost 20 years. They won't harm your engine.
Mine stays at 185 to 188 on the hwy. It might creep to 190-195 in traffic but it has never reached 200.
