Muddy, your understanding matches my observations. If you get stuck first, in a forward gear, then after stuck you shift into 4 lock, the rear wheels will need to rotate about 180°max before the front wheels can engage.
Similarly, many traditional 4x4 systems may require the same, in order for the forks to move dogs into place, meshing gears.
If already in four lock before getting stuck, as long as the front wheels are tracking over the road at the same speed as the rear wheels, the ball ramp will not be applying torque to the front wheels. If the front wheels begin tracking over the road at s higher speed than the rear wheels, such as while turning, the ball ramp will allow the clutch to slip.
Only when the rear wheels try exceed the front wheel speed does the ball ramp apply an axial force to the splined clutch basket closing the clutch plates. Given the surface area of the clutch plates and the mechanical advantage of the balls/ramps, the clutch should be transferring about 1200-1400 ft lbs to the front before any slipping or breakage of the clutch. With a 3:1 ish first gear ratio, it can likely transfer all the hemis torque without slipping. Remember, that the more torque the engine applies to the ball ramp, the more the clutch plates are compressed. The ball ramp has two possible states. It is either (unpowered/off/not allowed to engage) or it is (powered/on/allowed to engage). When it's powered, it will require somewhere between 0° and 180° of ∆< (change in angle) between the rear and front drive shaft.
I'm not sure how it works in reverse, I dont recall seeing any double Bi-directional ramps. Unless it has them, it would be relying on torsion spring alone for the axial clutch pack load in reverse and would really really suck.
But, while not ideal, based on observations of the guts of this case, if your in 4 lock ahead of time when you encounter slippery conditions,. The ball ramp will allow somewhere between 0° and 180° of ∆ < between front/rear wheels. Once the rear wheels slip.
So, to reiterate, unless I made a serious error in my observations, there is no electronic control of the clutch plates clamping force (for lack of a better term). The computer controls the ball ramp only, the ball ramp forces the clutch plates together.
In 4 auto, the computer sends power to the ball ramp when the wheels peed sensors detect slippage. It the shuts off power when the wheel speeds all match.
In 4 lock, there is continuous power to the ball ramp. Slip or no slip, constant power. I don't recall if the ball ramp is powered at tps -0- or if the throttle position must be a positive value first.
If your in 4 lock, applying power, the ball ramp will apply all of the engines torque through to the front wheels. This should occur before the rear wheels have rotated 180°.
The thing I haven't figure out yet is reverse. Think of the ball ramp as being like a ratchet, then spinning the ratchet handle backwards, it doesn't apply torque to the socket unless you change a setting. I don't recall seeing the mechanism that allows this.
It must have it though, otherwise the front wheels couldn't do anything in reverse. If the ball ramp is bi-directional, it would have another obvious downside. If all 4 wheels were spinning while trying to go forward, then you shift into reverse, the rear wheels will have to spin a few turns before the front wheels are engaged. Then the same again, when you shift back into drive.
Looks like that's the price to be paid for a 4x4 that doesn't bind in turns.
