Anyone running PW springs in a regular 2500 instead of a level kit?
pods8
Anyone running power wagon springs in a regular 2500, which should be 2" lift, rather than leveling spacers? If so how much lift did you actually get? I hear the springs are softer, does it ride nicer? Thanks.
Stangshcky12
Oshkosh, WI
5.9 Cummins
There are plenty of leveling springs out there that would be more inexpensive then power wagon springs
P
pods8
Running the part numbers for a set of powerwagon springs is ~$155 for the pair at the wholesale suppliers, that seems fairly reasonable to me...
Stangshcky12
Oshkosh, WI
5.9 Cummins
I would have expected them to be more.
Assuming you have a hemi 2500 since you didn't have much of an introduction, I don't think power wagon spring will get you level. I know of a few people with PW the run leveling kits still
P
pods8
Yeah I have the 5.7 (listed under my user name when I registered, sorry for the lack of intro ;)). As you mentioned there are lots of ways to pick up 2" up front if desired, I'm curious if the softer PW provides a nicer ride over stock springs or not.
PWs are also lifted in the rear so it would make sense that folks would need a leveling kit if they wanted to level them.
