Anyone use Mercon automatic transmission fluid in their 54RFE?
g-nut
South Alabama
Has anyone used Mercon transmission fluid in their 545RFE automatic transmission?
I have a 2004 Ram 1500 4.7L 2wd with this transmission. I'm planning to change the fluid and filter. I already have 2 new 5qt. jugs of Mercon LV trans fluid sitting around. I'd bought for something else that I ended up getting rid of. So I'd like to use it.
06 Dodge
6.7L CTD
Don't use it unless you have lots of coin to pay out having someone rebuild your transmission, use ATF-4....
FabricGATOR
Sailfish Capitol of the World, Florida
Anything on this list is bingo...
...even blue bottle from Walmart
Yes, it is more expensive than Mercon but it works correctly and all the others (including the universal the auto parts kids tells you) might not work too long.
**IF you are cross contaminated, you really should drain - drive - and refill three or four times to be safe
Fatboy1989
