- Jan 17, 2016
- 23,853
- 54,910
- 14 Sport
- 5.7
Wet rags draped over the exhaust or a long sleeved welding glove helps keep the cursing to a mininium,lol.Thank you. Yeah, the OE pan has the drain plug. I need to cut down an allen wrench if I don't have the right hex bit. I can see the tranny getting too hot to fill, especially if I do it on a warm day. Will try to do it in April sometime. Thanks for the temp tip.
Break the fill plug loose before you drain the transmission
If you have a helper to run it through the gears ,it usually helps to keep the transmission temps inline,so it doesn't get to hot,before you get through the procedure.
You'll want 6T jackstands,as most 3T stands aren't tall enough to get the transmission level,plus the bigger stands are usually more stable while the rear tires are in the air,and you have to go through the gears with the rear tires rotating fast enough the transmission shifts into 2nd gear
