Anyone using Andersen Weight Distribution hitch with air suspension?
Razzman
Southern Arizona
2020 Limited CCSB
Adding one to my trailer and wondering about the setup with factory air suspension?
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Ask and you shall receive...[emoji41]
Razzman
Razzman
Southern Arizona
2020 Limited CCSB
Yeah I saw that, but the Andersen is different as it doesn't use bars so there's no adjustment per se.
With the Anderson WDH, you tighten the chains to increase the weight distribution to the front of the truck. As the owners manual states you set the WDH up with the truck in jack mode.
There is a member on the Ram1500Diesel site that pulls a 8K toyhauler with his EcoD Laramie w/air suspension and an Anderson WDH set up. He really likes it.
corneileous
Podunkyville, OK
If it uses chains, it does. Or what hitch do you have? Is it like this one? I would say regardless of the style of WD hitch, the procedure would be the same. I mean, all you’re doing is just putting the truck in Jack mode which pretty much just disables the auto-leveling.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
My fastway had me lock air suspension height by going to tire change mode and the adjust bars back to level. Probably same for Anderson. Lock height and adjust like non-air.
Sent from my SM-T350 using Tapatalk
