At My Wits End - Blower Motor Won't Turn ON
Vulcan
Middletown, NJ
5.7L
Trying to help a friend who can't afford to take his truck to the shop. It's a 2017 Ram. A/C was working fine but the blower suddenly stopped. He claimed that for a while, in order to get it working, he had to play with different setting on the control knob, but then the motor quit completely.
I tested the cable at the blower's connector and was able to read 12v across + and -, and was able to see voltage rise and fall on the center control pin. Figured he had a bad motor, so I bought a motor for him but got the same problem. The blower fuse tested okay, and I even swapped it with a similar fuse with no luck. Also swapped the blower relay with the one next to it but no luck there either.
I read somewhere that there's been an issue with the ground wire being faulty, so I temporarily jumped a separate wire from a good ground to the - pin on the connector, but again, no luck.
As you guys probably know, this model truck doesn't have a separate resistor pack because it's built into the blower, so that's not an issue either.
Now here's something that's really got me stumped. Neither the original blower nor the new one will turn on even if I connect the + and - terminals directly to the battery.
Is it possible that the original blower actually went bad and we just happened to get a bad one from the store?
Please help. We're gonna have another 90+ degree week and he needs his truck for work.
Thanks
V
Vulcan
Middletown, NJ
5.7L
I originally poste this in the Audio and Electronics section. Got a lot of views but no replies, so I thought I'd try here. Hope this doesn't violate any posting rules, so here goes.
Thanks
Jeepwalker
WI
2012 Reg Cab, 4x4
What happens if you wiggle the fuse while trying the blower? Some owners have had burned contacts below the fuse or the TIPM harness/board.
Did you check out some Y/T videos? I see a bunch there on the subject. But I didn't watch them....
V
Vulcan
Middletown, NJ
5.7L
I pulled the fuse and the contact pins looked good as new - no burnt marks or corrosion. The fuse fits flush in its socket. Not sure if I can wiggle it, but I'll give it a try. I also tried Y/T, but all they show is the stuff I've already done.
What about the fact that when connecting the motor directly to the battery, that it still won't turn on. Does it need something from the center control pin to turn on even with a direct connection?
