Auto park disabled
1996smith
MS
Auto park disabled comes on my message center. Other dash light come on and flash and most times, my ram shuts off. After I turn key off and let it sit a minute or so, it goes just fine but starting to happen more and more. Anyone else have this problem and get the solution because no where around here or that I can find online, seems to know.
Jeepwalker
WI
2012 Reg Cab, 4x4
Did you do a search on this fourm? I recall seeing it come up in the past, but don't remember the 'fix'. Hopefully another forum user will chime in...
1996smith
MS
I never found the actual fix to it, if they figured it out
JBD123
Montana
I’ve got a 21 ram longhorn (5.7) non eco . Having the same thing happen. It’s happened 3 times now since I’ve owned the truck. All lights flash and then when I slow down to pull over and see what’s going on the embrace pops and skids me to a stop and the truck turns itself off.
Mb7640
Fountian hills az
Im not sure if this will help but I just went through this,this past weekend with the wifes challenger. It turned out to be the door was not making full contact with the door sensor. It was enough to not show a door open but it would stop the car and put it into autopark. You may want to check this out. I know its a little different but its the same system. The dealer had to adjust the drivers side door handle and reolace the inside portion of the passenger side
