Jessica Smith
I'm used to "manual everything" vehicles, from the transmission to the climate control.
Typically what I would do, and was told was best for maximum fuel efficiency is roll down all windows, leave AC at coldest setting, crank fan to maximum, and after rolling for a second close the windows, then once it feels a bit cool hit recirculate, when desired temp is reached lower fan down gradually to minimum, and IF that exceeds desired temp to hit the AC button to turn off the AC while fan is lowest, and then turn the AC on when needed again.
The idea is that the AC is most efficient at max cold, as otherwise its just mixing in hot air but running the compressor and fan just as hard.
But now that I have an automatic climate control, I really don't know what's going on behind the scenes when I let it do its thing, and if its following best protocol for fuel efficiency and getting to desired temp fastest.
So I haven't been using it much, but was curious if its just as good and using decent logic??? My unscientific feeling is that its not cooling down as fast. Thoughts?
