2013 Dodge Ram 1500 Single Zone AC Heater Climate Temperature Control Unit
tnctx02
2017 RAM SLT
3.6L Pentastar V6
I am hoping someone can help find the part number for a 2013-2018 Dodge Ram 1500 Single Zone AC Heater Climate Temperature Control Unit
I have a 2013 and every one I have tried for later year trucks after converting it to the 8.4 radio, my blend doors do move correctly.
I appreciate any help with this I can get!
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
As far as I know, they'll all work correctly (HVAC bezels). It may only be the HVAC module for 2018+ that differs...
@Mpgrimm2 might have the details (might even have a bezel to sell!)...
tnctx02
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Could you clarify, you put every one tried for later year trucks after converting to the 8.4 radio the blend doors do move correctly is that showing up as a problem? the part number is
1UJ96DX9AL https://parts.allmoparparts.com/oem-parts/mopar-center-stack-1uj96dx9al?c=az0xJnE9MVVKOTZEWDlBSg==
I have tried one that came from a 2014, 2016, and a 2017 in my 2013. With the original controls, the air moves everywhere I want it to from the floor to the dash, to the defrost. But not when I put the newer ones in it. Some are single zone and some were dual zone. All of them work just fine in my 2017, just not in my 2013.
Hope this makes sense.
2016 2500
Air Force
interesting, all with the same wiring harness? perhaps the wiring harness is bad?
tnctx02
tnctx02
2017 RAM SLT
3.6L Pentastar V6
I thought about that, but why does it work with the original controls with the 5" radio bezel then?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Sent you a message
2016 2500
Air Force
I don't know what your truck needs for the 8.4 upgrade, but mine uses the 5 inch screen, the 4 speed manual fan and the physical dial temp and vent/floor/defrost positions. for me upgrading to the 8.4 I need the bezel that has both radio and hvac controls on it. whether that is the single zone manual temp control, or the dual zone auto control. so that means I need a wiring harness that is made for the upgrade. if your truck doesn't need a harness for the upgrade then it don't make much sense to me.
ameer73
