automatic locks disable
cajun87
Louisiana
I just bought a 2013 and when i go over 15 mph the doors lock, anybody know how to disable the automatic locks?
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Have you checked the settings in the EVIC? Maybe you can turn it off that way.
Corbin
I haven't browsed thru the settings on a 2013 yet, but I know on a 2012 you can disable the auto lock feature. You would need to have a dealership hook computer up to change the settings. If I get a chance today, I will confirm if the setting is avail on a 2013.
Ramunit
With my 05 the instructions are in the owner manual, maybe it's the same for yours. It worth a shot. Within 10 seconds cycle the key from OFF to ON four times ending in the ON position. Within 30 seconds press the drivers door lock switch in the LOCK direction. A single chime will be heard to indicate feature has been disabled.
cajun87
cajun87
Louisiana
I tried that yesterday, and couldn't get it to work. Either I'm retarded or it doesn't work on the 13's.
Ramunit
Try this with EVIC system, Press the "UP" button on your truck's EVIC located on your dashboard. Press the button until the "System Setup" option appears in the EVIC display. Press the "Select" button.
Press the "UP" button until "Auto Door Locks" displays on the EVIC. Press the "Select" button to remove the check mark next to this option. Your vehicle's auto door lock feature is now disabled.
cajun87
cajun87
Louisiana
Got it guys thanks. The settings menu is in the settings on the radio screen.
Corbin
So I just checked a 2013, if you are unable to change the setting through evic, you dealer can change the setting in the BCM via diagnostic tool.
joshhhh
