Aux Switch Panel Not Energizing
Jholtzman1
Navy Badge
Yukon, OK
Hurricane HO
Recently added front parking sensors to my 2013 RAM 1500 Limited by installing sensors in the front bumper, built and installed a wiring harness, replacing the RF Hub, adding the guts of a 2017 RAM Speed-o-Meter, and replacing the original 2013 BCM with a new 2014 BCM. Everything works including the light indications for the front sensors EXCEPT I now do not have any power to my aux switch panel (panel and switches energized with the 2013 BCM installed). Is there a setting I need to change on the 2014 BCM? Thanks
Jholtzman1
Jholtzman1
Navy Badge
Yukon, OK
Hurricane HO
One correction: it is an Instrument Switch Panel (vice an Aux Switch Panel). I understand I will need to replace the existing panel with at least a 2014 which will have the Front parking Assist Off switch but still not understanding why the 2014 BCM is not powering up the existing panel.
