Aux Switch Panel Placement
Hammer757
Virginia Beach, VA
I'm trying to decide between trigger controller, Switch Pros, StechSwitch, and S-Pod. However, I was hoping to see some pictures of the panels mounted in different rigs to get some ideas on what look I might like. So let's see some pictures. I wish the PW had the built-in aux switches to get you started.
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
There is already a thread for this in the 4th gen section
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
There is a Uplifter switch option that hardly anybody gets. Mine was not optioned with one though it was on the list. Switch Pro is my first choice but I had a rough country Pod from my last build so I have installed it to run my lights for now.
56PW17
Pa
Is that a natural spot to locate the switches?
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
What Maligator posted. I have it in my 17 bighorn, love it for being close to oem
Hammer757
Hammer757
Virginia Beach, VA
I do like the Switch Pro, leaning that way (well until I saw that OEM look above). I do have the VSIM just not really sure how to use it, as it seems to tie into functions. Thinking I might be able to use it to make an air horn go off instead of the regular horn. Still researching that some.
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
I found that with out a center console like my last two trucks, my options in the PW are a little more limited to stay within reach. Super easy to install in this spot for sure. My last truck i installed it right where the four-wheel-drive shifter is on our trucks. (Side of the center console)
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
The OEM is preferable to me as well. mine will run up to 30 amps per switch and my onboard compressor pulls 22 amps having the most draw out of all my devices.
Badger 13
North Idaho
2013 Dodge Ram 1500
I went with the Spod since the 4th gen electronics wasn't available at the time. I do like the factory look, but I think my Spod looks good, and a great way to power up accessories.
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
That does have a nice factory look.
That's because it is factory. Why anybody would install anything else now that this is available is beyond me. When I get home I will take a picture of the underhood box. :)
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
not an option for 19. I have a thread that I started with this approach last year and ended with an aftermarket pod
56PW17
Pa
Current set up. Glad to have it back in place after taking the console out.
next project attempt is the ARB outback overhead console. Then I can mount my radio and this PA AUC controller in it.
TXTONKA
I went with the factory switch panel from 4thgenram. It's great and keeps the factory look with no extra panels to mount in the cab. It might be worth contacting 4thgenram, to see if they could make a similar panel for the 5th gen Rams. Since there is a panel you can install.
Timkll
