Back-up Camera
Docota
Virginia Beach
I have been looking into getting a back up camera for my SLT, but I had a thought. If I went to the pick and pull to find a '16 with the tailgate back-up cam, how easy would it be to replace that with my tialgate and have the cam hooked to the screen? Would it even work?
baum
savage, mn
2015 Laramie
so a search on here. you would be basically be doing the "factory" style install. many topics on here.
BiGMERF
2017 SLT 4x4
v6
when i installed my pioneer nex, i tinkered with the idea of a factory tailgate setup.. after looking at time and cost.. i opted for the simple license plate one.. $20 bucks and i had it installed in ten minutes
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I have been looking into getting a back up camera for my SLT, but I had a thought. If I went to the pick and pull to find a '16 with the tailgate back-up cam, how easy would it be to replace that with my tailgate and have the cam hooked to the screen? Would it even work?
You could use he tailgate but all you need is the tailgate handle w/camera. Then you need the wiring harness from the tailgate to the cab and then you have to go to dealer to get the computer flashed ! ( not sure about after market ) I have a 2015 SLT and had dealer install the camera kit. I figured since I would have to got to the dealer anyway killed 2 birds with 1 stone :),,Plus they warranty it Cost was around $525.00 installed.. BUT some dealers charge as high as 1200 $ from what I have read . The OEM Camera/harness kit is around 300$ . Several here went aftermarket.. As mentioned several threads here onsite about adding it, I saw it as too much a pain in the ass for me to do lol Also go t You Tube there are videos showing how to do it
baum
savage, mn
2015 Laramie
hooking up to the factory is nothing like using an aftermarket cam and aftermarket radio.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Read this....
Installing OEM backup cam
** Pay attention to Post 10 as well as the OP **
Unless you get a smoking deal on the used parts out of a wrecked trucks tailgate, it usually makes better sense to get the Mopar camera kit so you have all the parts you need. ( about $280 for the kit & $120 for the flash at the dealer)
M² Mods.
R.L.K.
Bristol , Tn.
Read this....
M² Mods.
This ^^^^^^^ [emoji1303][emoji1303][emoji1303]
Less than $300 from the dealer for the kit and install yourself .
Pretty simple a 3.5 difficulty out of 10 for a dryer imo .
A couple electrical connectors to depin and populate , one or two solders ( depends on your BCM configuration ) and a bunch of tie wrapps for the long harness , rewarding to do it yourself imo .
