Backup Camera Blue Screen
mamabear12
California
We’ve had our truck for only 3 days now and today when backing up the screen goes blue. Sometimes it will show an image from the last time it was in reverse but it only goes away when the truck has been off for awhile. Any ideas what could be causing this?
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
It might be lose ... might was doing that for a while and recently I removed my tailgate and had to disconnect the camera harness, when I did so I found that it was not properly seated all the way ... it hasn't done it since ... check that the harness is nice and tight
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
As was just mentioned, the most likely problem would be the connection that is hidden by the license plate
2018 2wd
I called the dealer when it first happened and they swore up and down it was an update that needed to be added ... I took it they said nothing was showing up that needed flashed lol .... so first check the connection that is what fixed mine
GTyankee
3.0 ecodiesel
If you had your truck bed sprayed
They remove the tailgate to do that
They also remove the tailgate inspection plate so they can get better coverage
There is also another camera connection & the camera itself behind that plate.
You may also find another connection on the drivers side, where the back of the rear tire & the trucks frame, come close to the spare tire
( my 2016 Ram has one there )
TaterBigHorn
What’s the easiest way to get to that connector? I have a brand new 2022, not even a month old and I’ve been dealing with a random blue screen since the second week.
I took off the panel on the tailgate but I don’t see anything loose. Can anyone help ?
GTyankee
3.0 ecodiesel
Look behind the license plate general area, the wires come out of the bottom of the tailgate & pass through the sheet metal just below the bed.
May i suggest that you spray some Electrical Contact Cleaner onto both sides of the connector after you separate them
see the cut out rectangle above the plate ?
DEVON HANDY
mississauga
hi, i have a 2019 ram 1500 classic with 125***km and my reverse camera just went blue yesterday and it hasn't come back on since. the radio interface works perfect just the blue screen happens in reverse only. PLEASE HELP!!!!!!
