Bad cat?
BillsOldDodge
Petronila Texas
5.2 Magnum
Trying to figure out if my converter is bad, truck will not accelerate up to speed, is overheating, got a whistle from my exhaust- which seems to not be free flowing at all; and under no load- sitting in park or neutral, truck won't run up past about 2800-3000 rpm, then dies back down.
Thoughts?
TIA.
Bill.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
Definitely sounds like a clogged cat.
An alternative diagnostic test is to let the engine reach full operating temperature, then shift the transmission to neutral and step on the gas. If the engine will not rev past 3,000 RPM, either the cat's plugged, or someone stuffed a banana in the tailpipe.
Joe w.
Virginia
318 5.2l
I think my cat is clogged I've noticed loss of power especially up hills and at wot,seems like the more gas I give the less power I have.
Raadz
