Bad CV axle ?
elkskins_j
WV
I have vibration at speeds above 55 and below 75. Still a little after 75 but not as much. Well, I've had new tires , still had the issue, just recently replaced both wheel bearing hubs and new rotors all around and of course pads, still does it. Could a bad CV axle be the culprit ? When changing hubs our it did seem like my driver side CV axle rotated a bit funky.
Jeepwalker
WI
2012 Reg Cab, 4x4
You could remove the load on the CV and get under there and violently shake the CV and see if you 'feel' play. Shake your f driveshaft too. How many miles on your hot rod?
So, it 'could' be a CV, but often times its tires, a bent rim ...bad u-joint, etc.
Curt Gobbell
Memphis TN Area
HEMI 5.7L
Could you remove the 2 front CV axles, drive it in 2wd for a day and determine if the vibration went away?
May be too much trouble...but a thought
elkskins_j
elkskins_j
WV
Possibly. I'm at 130000
elkskins_j
elkskins_j
WV
Actually didn't know thus was possible. I'm not exactly a mechanic.
