Justin_case
- Dec 12, 2016
- 8
- 4
- 2006
- Cummins 5.9
I have a 2006 dodge dually 2wd with the 5.9 cummins. I have 198k on motor and trans and on a recent trip I began to hear a howl that is most noticeable when I let off the throttle. When I slow down at between 10-15 mph there is a severe shake similar to hitting rumble bars on the side of the hiway. The shake seems to be worse if I'm applying the brakes at that speed. Could the torque converter be causing the howl and shake? Carrier bearing for the drive shaft and u joints are all new and were replaced after this problem was discovered. I've seen threads talking of noisy TCs but can't find anybody that's had the shake. Thoughts??
